Clutch adjustment help
Old Apr 4, 2015 | 06:03 PM
1983Z28Custom's Avatar
Car: 1983 Camaro Z28
Engine: 5.7 liter V8
Transmission: 5 speed manual trans
I installed a new clutch,had the fly wheel turned, put a new throw out bearing in,etc and now my clutch pedal has does not engage until its to the firewall, and even then its not enough to put it into gear. I need a new ?clutch adjustment rod? if thats what its called, but advance,auto zone,napa, etc all say that part does not exist in there data base. I measured and i need a 10 inch rod to get it to work right and i dont know if what i found on the internet is 10 inch.... If anyone knows of a site that sells what im looking for, please send me the link and i would be eternally grateful.
Old Apr 4, 2015 | 06:24 PM
Re: Clutch adjustment help
No, no, no, and no.
Which of course, is why you can't find one listed: you don't need one besides the one you have now.
Which way did you assemble your throwout to your fork?
https://www.thirdgen.org/forums/atta...g-assembly.jpg
Old Apr 4, 2015 | 06:37 PM
It occurs to me also, that you may have the wrong throwout for your clutch, if it didn't come as a set...
https://www.thirdgen.org/forums/atta...ut-bearing.jpg
Note how this throwout is a bit taller than the one in the assembly pic; has that extra little "shoulder" to it. Low-perf clutches tend to use this style, so if your clutch was kinda the "low-bid" option, might need one like that.
Old Apr 4, 2015 | 07:45 PM
I did hook up the fork the correct way that the picture shows and the bearing did come with the clutch. The clutch is not a cheap one either, its a heavy duty one and it was the best one the auto store sold. I had a retired mechanic help me put it in and he said he has run into this exact problem before and fixed it by buying a longer clutch adjustment rod. If you have any other suggestions I would try them, but Im pretty sure it just needs a longer adjustment rod but we could both be wrong so Im open to any help.
Im thinking this might be long enough but the length is not listed. http://www.jegs.com/i/Auto+Metal+Dir...FUIV7AodmDEAMQ
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
