Removing brake booster/master for T5 conversion question
Old May 4, 2015 | 08:45 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I assume the brake lines need to be disconnected for this? Does the whole unit need to come right out of the car or is there enough flexibility to leave it all connected? I've never pulled a booster before.
Old May 4, 2015 | 01:43 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Re: Removing brake booster/master for T5 conversion question
When I did mine I never removed the brake booster. I removed the nuts to swap the pedals, but that was it. No reason to remove the booster, just work around it.
Old May 4, 2015 | 01:48 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
You were able to mount the clutch master with that in the way? It looks like a dogs breakfast in there.
Old May 4, 2015 | 02:06 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You may find it easiest to remove the booster, leaving the MC in place. The brake cables will hold it fine. Either way you'll have to undo the bolts to the booster on the inside to remove/install the pedal assembly.
I also removed the seat and steering column for easiest access to the inside firewall.
Old May 4, 2015 | 02:22 PM
I was able to mount the clutch master twice with the brake system bolted in. I am 24 and somewhat flexible still & pretty stubborn. It is defiantly tight quarters in there
Old May 4, 2015 | 10:43 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
It's not required to remove the booster.
Some people see with their hands. Others feel with their eyes. Do what makes you happy if the little extra time pulling the booster out a little makes you more comfortable.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Royal_Z
Sep 30, 2015 08:45 PM
92projectcamaro
Sep 29, 2015 07:07 PM
