Mechanical to Electric Speedo
Old Jun 19, 2015 | 08:40 PM
V1nom's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
I have an 1986 Camaro Sport Coupe with 383 Stroker & 700r4 Tranny. It has a mechanical speedo and I bought "New Vintage USA 1967 Series" which are electric. I just want to double check and make sure these are the parts I need to convert the mechanical to electric. Will I need any other parts besides these or no.
VSS: http://www.summitracing.com/parts/rpc-250-4153/overview/
Daktoa Box: http://www.summitracing.com/parts/dak-sgi-5
Old Jun 19, 2015 | 10:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Mechanical to Electric Speedo
If you have no ECM, you can use just about whatever VSS you want 4,000 pulse/mile or higher. Those gauges are okay with square or sine wave and self calibrate. So you wouldn't need the SGI-5 Dakota box.
If using an 80's third gen ECM, you'll need something to cut down the signal to 2,000 PPM; the Dakota can do that. 1980s fireirds and TBI 90s models did it with a VSS buffer.
Old Jun 19, 2015 | 11:16 PM
V1nom's Avatar
Engine: 383 Stroker
Okay, I believe its the original ecm I bought this car last year and don't think the previous owner change any of that stuff. So thats the part I only need to get my gauges to work.
Old Jun 19, 2015 | 11:26 PM
jmd's Avatar
jmd
Maybe not; I edited my post.
The stock 86 speedometer has an optical VSS that feeds the ECM and cruise.
In short, you will need the Dakota. Or a VSS buffer setup like used in 80s model third gens and TBI models.
Old Jun 20, 2015 | 02:43 AM
V1nom's Avatar
Engine: 383 Stroker
Alright so use the Dakota and that VSS #2PRS from Jasthatfun website?
Old Jun 21, 2015 | 04:14 PM
jmd's Avatar
jmd
Sorry, no; that was my suggestion if you were feeding speedo only; you have an ECM.
I can't find anything that says what pulses the New Vintage USA sender puts out. Jegs has a knockoff of it for $5.00 less: http://www.jegs.com/i/JEGS-Performan...41610/10002/-1
That plus the DD SGI-5 C would work for you.
Per the Dakota Dig. manual Application 5 http://www.dakotadigital.com/pdf/sgi-5c.pdf , you'll use output 5 for 2000 pulse per mile switches (square wave) to ECM, and output 3 for 4000 pulse per mile to speedo, or output 1 for 8000 pulse per mile to speedo. The manual for your speedo didn't make it sound like it mattered.
Hotrodboba400
Dec 10, 2019 07:07 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
TrevinE
Sep 14, 2015 03:20 PM
webeeZ28
Sep 14, 2015 12:00 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
