help getting flywheel for t5
Old Jun 25, 2015 | 08:42 AM
jdreswick's Avatar
Car: 1986 Trans Am
Engine: 327 .030 over sbc
Transmission: wc t5
Axle/Gears: stock
Hey guys I need some help I got a 68 327 and I was wondering if anyone knew what flywheel to use with my t-5. my old one is off an 86 305 so it wont work. I assume I can just get an 82 to 85 flywheel and that should fit. I just want to make sure. Maybe you guys have run into this before thanks.
Old Jun 25, 2015 | 01:16 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: help getting flywheel for t5
regular small diameter (153 tooth) flywheel for any generic small block made from 55-85 will work. hell, you could even tell the guy that you have a 68 Chevelle with the inline 6 and a 3 on the tree and it would be the same thing..
Old Jun 25, 2015 | 01:34 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I believe the factory 84ish l69 flywheel is a bit lighter may be worth considering.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
