454 to LT-1 T-56
Car: 1991 Camaro RS
Engine: 454
Transmission: t56
454 to LT-1 T-56
I have a lt-1 style t-56 trans that is currently running behind a 94 350. My question is if I can use the 1pc lt-1 neutral balance flywheel combined with a 454 porkchop weight on my 1999 454?
Car: `86 SS / `87 SS
Re: 454 to LT-1 T-56
It's a different bolt pattern at the crank.
Also, the pull clutch is sensitive to too-thick clutch assemblies including things like taller flywheels or flywheels made taller with sandwiched weights. You would probably find a 0.100" thick weight to prevent proper clutch release.
Centerforce adaptive flywheel is the simplest, based on parts you probably already have.
Call them. They, or Spec make one to suit the unique 454 balance, old bolt pattern, and 153 tooth ring / starter setup.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
