New Billet Spec Twin-Disc Clutch
Old Nov 1, 2015 | 10:43 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
This thing is so pretty, it's going to be a shame to cover it up. It's a 168 tooth/11" flywheel setup with two full-face semi metallic discs. Should hold 1,500 ft/lbs.
Old Nov 1, 2015 | 11:32 AM
Re: New Billet Spec Twin-Disc Clutch
That's AHELLUVALOTTA mass to synchronize during shifts.
Still, I bet it won't slip.
Looks like there's no reason it couldn't be used on a 12.8" wheel as well.
Old Nov 1, 2015 | 11:56 AM
Car: '91 Camaro RS
Problems solved by not having synchros (2nd, 3rd, and 4th are faceplated).
It's really light though, the entire assembly with the flywheel is only 34.8 lbs. I'll likely need to actually add RPM on the launch to compensate.
ZsTransAm
Nov 2, 2015 06:06 PM
Galaxie500XL
Oct 31, 2015 03:29 PM
crossrush
Oct 31, 2015 03:15 PM
sleprock
Oct 28, 2015 01:32 PM
tcrisp
Oct 26, 2015 08:23 PM
