406 w/T56..what flywheel??
Old Dec 21, 2001 | 10:14 AM
1985_glue_factory's Avatar
I am looking at getting a T56 swapped into my 85 Camaro which used to be a 700R4 and is now a TH350. I guess I am familiar with the swap with a 350 or a 305, so that doesn't concern me. What does is what flywheel to use with the 406. My motor is internally balanced.
Thanks!!
Dave
Old Dec 21, 2001 | 01:46 PM
poncho9789's Avatar
Both the t56 flywheel and the 400 flywheel are externaly balanced but other than that I don't know if the bolt pattern would be correct. IE the alijnment dow pin in the crank is the same.
Old Dec 21, 2001 | 05:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 400 has a 2-piece rear main seal, the T-56 flywheel is designed to bolt to a 1-piece RMS crank. The bolt patterns are very different. There is no possibility of any stock T-56 flywheel working.
It might be possible to get a good quality 153-tooth 400 flywheel from one of the few aftermarket mfrs such as Centerforce (they may be the only one) and drill the T-56 clutch pattern in it. I'm not sure what if anything is different about a T-56 clutch compared to a 10.4" one.
Old Dec 21, 2001 | 08:03 PM
irocbsa's Avatar
You can have Centerforce fab you up a custom one for about 4 bills.
bsa
Old Dec 21, 2001 | 08:24 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Dose anybody the clutch bolt patteren is for a T-56?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
