7.625 Interchangeability
Old Mar 19, 2016 | 01:29 AM
EastBoundNDown's Avatar
Does anyone know with 100% certainty if a carrier/gearset out of a 4th gen 10 bolt will work in a 3rd gen housing? from what I can gather it looks like it will, but I want to be sure. Thanks!
Old Mar 19, 2016 | 07:44 AM
big gear head's Avatar
Re: 7.625 Interchangeability
Yes, it will work as long as the axle splines arfe the same. All of the 4th gen 7.6 rear ends had 28 spline axles. The 3rd gen cars had 26 spline axles up to '90 and then they had 28 spline axles. All of the internal parts from a 7.6 will fit the 7.5 as long as the axles match. You can use '90 to '92 28 spline axles in the earlier rear ends that had 26 spline axles.
Old Mar 21, 2016 | 04:21 AM
Thanks for your expertise Gear Head. I'm putting together a 10 bolt for my 86" T/A. I pulled the Auburn unit I have apart to find that it has a cracked cone. I was planning n buying a gear set for it, but I found a low mile Torsen unit with 3:42 gears for about the same price so I pulled the trigger, just wanted to make sure it would work!
Old Mar 21, 2016 | 06:51 AM
Yup, it'll work, as long as you use 90-92 axles.
Old Mar 21, 2016 | 06:59 AM
Yeah I have a set of Strange 28-spline👍
CHAMARO
Mar 27, 2016 11:21 PM
91banditt2
Mar 18, 2016 07:12 AM
Faz87_355sb
Mar 13, 2016 01:13 PM
