trans temp gauge manifold size???
Old May 11, 2016 | 02:59 PM
BOTTLEDZ28's Avatar
Transmission: A4
Would anyone happen to know the size of the transmission cooler lines on a 91Z28? I will be adding an Auto Meter trans temp gauge and will be using one of their manifold T adapters but they offer it in two sizes. Sales dept is telling me I need to use compression fittings with implies that I have to cut my transmission lines and install new fittings. I do not want to do that. I need this to be a simple install. So, what are my option, and dont say thread into the pan. I am not doing that. Car is too low and I will not risk the sender getting knock off from debris.
I have heard of people using the pressure test port on the side of the trans but I do not know if that will work or not. Opinions???
Old May 16, 2016 | 09:26 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: trans temp gauge manifold size???
Test port will work. It'll give an approximate reading, but there's plenty of people using them. Keep in mind that the trans temp sender is npt and the transmission case is straight thread, overtighten the sender and the case will crack.
Old May 19, 2016 | 02:24 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I'm using the test port as well w/ a speedhut gauge on the pillar.Temp is spot on compared to my laptop software.
Old May 19, 2016 | 11:26 AM
BOTTLEDZ28's Avatar
Transmission: A4
Are you guys using thread tape or paste on the threads of the sensor provided in the gauge kit?
Old May 19, 2016 | 12:37 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I used a lil bit of tape.One pass actually.
Old May 19, 2016 | 09:19 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
I think I used a dab of grey silicone. I think I ran out of tape earlier in the day and I needed it done. Not leaking yet, so I guess it's working. Lol
Bluestreek
Apr 19, 2017 03:16 PM
b2tw45p
Mar 30, 2016 06:33 PM
UltRoadWarrior9
Mar 29, 2016 06:48 AM
mballejos87
Mar 26, 2016 09:26 AM
5.7RamJet
Aftermarket Vendor Review
Mar 19, 2016 06:38 PM
