Hooker T56 crossmember speedometer issue
Old Dec 28, 2016 | 09:08 PM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
So I removed my Hawks T56 crossmember and started installing my new Hooker crossmember. Hooker setup is better in every way plus moves the torque arm from the transmission to the cross member.
Half way through the install I found an issue. If you are running a modified tail housing to run a cable driven speedometer as I am there are some clearance issues.
So I am going to remove some material in this area to make room for my speedometer cable.
Anyone think this will compromise the strength to my new crossmember?
Old Dec 28, 2016 | 10:57 PM
Drew's Avatar
Re: Hooker T56 crossmember speedometer issue
90-degree adapters for speedometer cables exist. For that matter, I'm sure one of my cars had an aluminum shield clipped on the end of the cable to hold it to a soft 90-degree bend, could have been on my Mustang... I doubt a clearance cut would effect the overbuilt crossmember, it'd just be a lot easier to move the cable out of the way.
Old Dec 29, 2016 | 05:49 PM
TORN's Avatar
Car: 88 IROC-Z
Fixed it.
Old Jan 4, 2017 | 06:10 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
def be buying one of these, since Skulte went out of business no one around to make them where did you buys yours from?
Old Jan 8, 2017 | 04:47 PM
TORN's Avatar
Car: 88 IROC-Z
Holley Christmas Sale.
Old Jan 17, 2017 | 11:12 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Torn, glad you posted this, i realized my Spohn xmem was in for a collision with my LTs im getting. 5 mins later i had a solution figured out.
mount a piece of channel on the side the trans tail sits on and then cut away the area underneith. this will mod it and keep the angle correct.
