Trans mount?
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: Trans mount?
Go down the road and floor it, then let off, if it sounds like it's hitting the floor with a bang and you can feel it, your mount is bad. They are very very cheap, think $8 or something from pep boys for rubber.
Car: 1988 Firebird
Engine: 2.8
Transmission: THM 700R4
Re: Trans mount?
i am hearing like i am dragging something under my car right at the shifter. only thing that is happening.Also i'm not gonna even attemp the flooring it. Come on!! lel
Car: 1991 Camaro RS
Engine: Hot 355ci
Axle/Gears: 4:10
Re: Trans mount?
Just give it some gas in gear. Could also put a jack under the trans and just barely touch it and see if it comes up. Or you can take it out in about 2 minutes and check it.
