700r4 not shifting into 3rd and 4th
Old Jan 19, 2017 | 06:23 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
So, about 6 months ago I had a shop put in a brand new 700r4. It worked flawlessly no problems whatsoever up until recently. I just replaced the carpet this past weekend and had to take out the center console and things like that to replace carpet. When I got the carpet in and put the console and everything back together I took it for a test drive and it wouldn't shift to 3rd or 4th. It also bogs really hard in 2nd. So I adjust the TV cable and then it started shifting fine again. The next day I take her out and it's doing the same thing, so I adjust the TV cable and it was running good again. Now today it's doing the same thing. Please help I need this car running as it's my daily driver!!! Thanks.
Old Jan 19, 2017 | 07:23 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: 700r4 not shifting into 3rd and 4th
the tv cable isnt for adjusting, its for setting to the one correct position. incorrectly adjusting the tv cable will burn up a transmission.
I just did the carpet in my thirdgen this summer and removed the entire interior except for the dash and I can't really think of anything in the center console area that would prevent 4th gear from engaging.
Old Jan 19, 2017 | 08:18 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Ok, also I noticed their was a frayed and rusted cable that ran from the shifter to the drivers side foot well to under the pedals through the firewall. I wonder if that is the issue, and if you know what the name of that cable is that would be great thanks.
Old Jan 19, 2017 | 08:26 PM
TylerSteez's Avatar
Engine: 383 stroker
that sounds like the cruise control cable
Old Jan 19, 2017 | 10:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Two cables run from the shifter.
One is the shift cable that routes to the transmission. The other is the park/lock cable. It routes to the steering column.
Make sure that the shift cable is properly adjusted and that you're not "in between" gear ranges.
Old Jan 20, 2017 | 09:40 AM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Ok, thanks for the info hopefully it wont be too hard to do.
