clutch hydraulic line replace ouch
Old Feb 4, 2017 | 10:57 AM
mcbitchman's Avatar
Car: 84 s/e, 94 must conv, 66 must
Engine: 2.8 v6
Transmission: 5 speed manual
Axle/Gears: 3.42 posi just chngd from 3.73
OK so it looks like the clutch hydro line is a joke.. to replace. any ideas on total replacement of the system incl master and slave along w/ the offending pipe...? this is what I call sonofabitch engineering... designed to make you say "sonof a" and take your car to the dealer for service... bad GM bad boys.... how about removing the brake master ???? anythings got to be better than what I've read about this line... thanks Doug
Old Feb 4, 2017 | 11:53 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: clutch hydraulic line replace ouch
I'm not really Sure what your asking for? The complete assemble with the clutch master, line, slave and reservoir is readily available and well as the 93-97 Lt1 style setup which also works and has a braided steel line.
Everything unbolts as an assembly, 2 nuts by the pedals to remove the u bolt.that holds the master to the firewall, and two bolts on the slave on the side of the bellhousing. A couple screws fir the reservoir and the entire assembly comes out. No real need to remove the brake booster unless you feel the need.
Old Feb 4, 2017 | 12:24 PM
Right, takes about a half-hour to replace the whole shebang, if you're slow like me. You're probably faster though, you can probably have it done in half the time. Looks scary but is really a piece o cake.
Old Feb 27, 2017 | 07:38 PM
Cesar Martinez's Avatar
Where can I find a kit? I have an 89 iroc and want to replace it all fresh. Car has been sitting for 10 years. Or one that will bolt up from a newer model?
Old Feb 27, 2017 | 09:38 PM
Try www.rockauto.com
Old Feb 28, 2017 | 10:18 AM
They have the slave and master cylinders. Looking for a complete assembly. Found one for 280 in New York. Anything cheaper another year model swap maybe?
Old Feb 28, 2017 | 04:58 PM
AFAIK all years fit all cars.
I had a 91 (I think...) assy on the 84 stuff that was in my 83 car, after the 84 parts gave up the ghost. Seems like I went to the stealership and they showed different part #s for just about every year, but they only had the one year in stock, so I bought it, and it was perfect.
