Clutch problems
Old Apr 7, 2017 | 12:28 AM
fgj777's Avatar
Clutch problems
So I recently finished a motor swap and installed a new clutch and I'm having problems with the clutch. The problem is when I push the clutch pedal down there isn't much resistance to begin with and I can change gears with the stick with out pushing the pedal down and I'm not sure what to do about it. Is there a way to bleed the lines?
Old Apr 7, 2017 | 06:50 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: Clutch problems
A little more information would go a long way toward figuring out what's going on...what clutch and transmission? What did you use for the hydraulics? What year car, and did the car originally come with a manual, or is the car swapped?
Old Apr 7, 2017 | 01:35 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Clutch problems
Did you install the throw-out bearing correctly? That is a common issue
Old Apr 7, 2017 | 03:19 PM
fgj777's Avatar
Re: Clutch problems
The car is a 1985 trans am and it came with the t5 from factory. The clutch is just a stock replacement from summit. Would I be able to check the throw out bearing with out taking the transmission off? Thanks for the replies I appreciate it!
