Clunking from reverse to drive, also whines on deceleration
Old Apr 9, 2017 | 10:33 AM
z28 prime's Avatar
Car: 91 z28 camaro
Engine: 5.7 tpi
I lowered my car using Vogtland springs and founders upper relocation pan hard bar, adjustable pan hard bar, adjustable tractions bars and traction bar relocation brackets. My question is now after changing all that and getting the axle centered w/ the pan hard bar along with centered in the wheel well. My axle is now clunking from reverse to drive. I did change the gear oil while I was under. I used 80-90 lucas with additive, since it's a posi eaton unit. It also whines only when I let off the gas. I'd say between 45-20. What would cause this to all of the sudden happen? Otherwise the diff. is fine. Any help would be great. Thanks
I'm thinking it maybe the pinion bearing making the whining noise and the clunking is or maybe coming from the torque arm bushing. It looked like it had some slop in it after getting it aligned properly.
Any suggestions would be great. Just incase I missed or over looked something. Thanks for everyones help and or opinion.
