700r4 downshift issue
Old Apr 14, 2017 | 07:27 PM
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
Finally got the trans in the car and took for a test drive.
When I'm slowing down and the trans down shifts, it slams down into the next gear. Harder than if i manually down shifted it. Never had one of my transmissions do this after a rebuild.
Anyone maybe have an idea what might be causing this?
Old Apr 15, 2017 | 03:17 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: 700r4 downshift issue
Is the TV cable adjusted properly?
Old Apr 15, 2017 | 04:26 PM
Car: 1980 Regal
Best I can tell. I am getting a pressure gauge so I can confirm what my pressures are. I'm sure that will tell a big part of the story.
Old Apr 20, 2017 | 07:17 PM
Car: 1980 Regal
Well, "best I could tell" wasn't even close on my tv cable setup. While it looked spot on it wasn't even close. A word of advice to everyone, get yourself a pressure gauge to set your tv cable properly, it's the only way to do it right.
Transmission downshifts much better now, however, when I put it in Reverse, it slams into gear. Seeing as I didn't modify the Aux VB, I don't like this. I will need to investigate and fix this.
