1987 Formula Differential Change
Old May 5, 2017 | 10:04 AM
PlanoDragon's Avatar
Car: 1987 Firebird Formula
Engine: H305
I plan on changing the rear differential fluid in my 1987 Formula Firebird and need to know what fluid to use.
It is a stock rear end, and I know that it likely was never done by the original owner.
Can anyone please tell me what fluid to use? Capacity?
Old May 5, 2017 | 10:32 AM
big gear head's Avatar
Re: 1987 Formula Differential Change
You will need about 2 quarts of 80W90 gear oil. If it has a limited slip differential then you will need the GM limited slip oil additive.
Old May 5, 2017 | 10:42 AM
Engine: H305
Thanks.
I have no idea if it has the limited slip differential though. No build sheet or data from original owner.
Old May 5, 2017 | 10:47 AM
If it has the 9 bolt Borg Warner rear end then it's almost certain that it does have it. If it's the 10 bolt then it could be either way. Do a burnout and see if both tires spin.
Old May 5, 2017 | 11:09 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
For the 9 bolt, do not use the GM non-slip additive.
For 9 bolts w/ posi:
Torco A248514CE 85W-140 (need 2 bottles)
Torco AFM0050JE Type F Limited-Slip Additive (1/2 bottle or full bottle, suggestions vary)
Old May 5, 2017 | 03:05 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Originally Posted by PlanoDragon
Thanks.
You will know when you pull the cover. Makes it hard to buy supplies in advance, but you could always buy the additive & return it if you don't have limited slip.
Old May 5, 2017 | 03:35 PM
Engine: H305
Makes sense. I also saw that you can tell if you raise the rear end, spin one wheel, and see if it spins in the same direction.
Is this right?
Old May 5, 2017 | 04:31 PM
That doesn't always work. Don't trust that method.
rs90083
Exterior Parts for Sale
May 5, 2017 10:02 AM
