Transmission won't shift out of first gear from a stop
Old May 24, 2017 | 12:09 PM
18Daytobre's Avatar
I have a 1985 Pontiac firebird and whenever I give it full throttle from a stop it won't shift out of first and will just rev out until I let off. I tried shifting the car manually but even then it would rev out when I would shift it from first to second, I was wondering if anyone else has had this problem and could tell me how to fix it if it's the detent cable or if there are bigger issues in the transmission. Thank you
Old May 24, 2017 | 01:03 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Transmission won't shift out of first gear from a stop
Make sure your fluid level is correct (you need to check it correctly)
and
Your TV cable is set correctly
Old May 24, 2017 | 04:17 PM
18Daytobre's Avatar
Do you want the little black part that comes out of the TV cable to be in as far as it can go or how should that be set?
