Aluminum drive shaft u joint
Old Jun 16, 2017 | 06:59 PM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
Hi all, I bought an aluminum drive shaft for my 85 z28 a few years ago and the bearing in the tailshaft went out. It wore a groove into the yoke and tranny fluid will spit out on acceleration. I put the original steel shaft back on after changing my the bearing and now I'm wondering if I can take the yoke off the original shaft and put it on the aluminum one. The original has the clips on the inside of the u joint and the aluminum has the clips on the outside of the u joint. There is a stamp I found that says "spicer" on the aluminum drive shaft.
thanks
