77mm manual transmission
Old Jun 21, 2017 | 01:02 AM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Hi all,
I have a1986 Camaro Irocz that I replace a 350 crate engine. I still have the original manual transmission which the manual describes as a 77mm 5 speed manual. It a has whining sound only when engage in gear and goes away when I press the clutch. Couple of questions:
1- Any idea what the sound might be? maybe the rear axle?
2- Is there any rebuilt kit for this particular transmission?
Any help is appreciated.
Thanks!
Old Jul 7, 2017 | 11:38 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 77mm manual transmission
If you have the factory trans then you have a T5 and there are plenty of rebuild kits available
Old Jul 7, 2017 | 10:35 PM
podiatra's Avatar
Engine: 350 swap
Thank you!
