Can the TH700R4 Governor make a rattling noise?
Old Jul 2, 2017 | 10:48 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
This is a continuation of a "ball bearings in a tin can" noise I have been getting for a few months now. After a lot of specific conditional tests, I have narrowed it down to a very specific set that point towards the transmission.
1. Never makes noise in Park or Neutral
2. The noise exists ONLY between 600-700 RPM. (550 RPM idle in drive, it goes away. Above 700 RPM it goes away until the RPM falls back down.)
The car generally runs fine. I completely flushed the trans and replaced the filter. I used Mobil 1 ATF. I also did the Corvette Servo.
I did not take notes, but the noise could have first appeared shortly after I did the ATF change. When I first got the car, it did not make this noise.
Old Jul 4, 2017 | 02:21 PM
firefox7518's Avatar
Car: 1989 TransAm GTA
Engine: 350ci
Transmission: TH700
Axle/Gears: Stock 9-bolt
Re: Can the TH700R4 Governor make a rattling noise?
I have exactly the same thing! When putting the auto into 3rd or 2nd it's even getting louder. It's less annoying in D but you can still hear it while driving slow. It sounds like a noisy shifter on a bicycle where the chain is constantly scratching through gears.
Maybe someone can give us a hint. My Auto is shifting good and firm but just makes this annoying noise.
Old Jul 4, 2017 | 06:36 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I have the same noise and it appeared after my oil and filter change as well
Old Jul 5, 2017 | 01:11 AM
Engine: 350 TPI L98
Transmission: WC T5
This is good. Let's stick together and see if we can't figure this out.
I will be diving down to inspect the flex plate and bolts in the next couple weeks (sorry busy right now) I will report back.
Old Oct 27, 2017 | 10:44 AM
Engine: 350 TPI L98
Transmission: WC T5
Follow up: It was the timing chain and gears they were original and very slack. Replaced and everything quieted up and engine ran a lot better.
Old Aug 2, 2020 | 07:14 AM
Jeremy Brown's Avatar
those transmissions have a govornor? Wow 😳 I never knew that. That’s crazy for real I didn’t know that but have owned so many of them
