Clutch Fluid Won't Bleed
I am doing a clutch swap and needed to replace the slave cylinder as well. After replacing I can't get the clutch fluid to bleed.
I filled the slave cylinder with fluid and installed it, then and had a friend push in the pedal so that I could crack the bleed screw and tighten it again per the proper bleeding procedure. The first time he pushed in the pedal the slave cylinder moved, but as soon as I opened the bleed screw the pedal went dead and stopped moving the slave at all.
After trying a couple more tries I gave up and removed the bleed screw so that I could pull vacuum on the system with a mighty vac. The system holds vacuum and I got up to above 20" mercury but no fluid moves.
Anyone got any ideas on how to get the fluid moving through the system? The pedal was pretty firm the first time, so I kinda wish that I hadn't tried to bleed it at all
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Clutch Fluid Won't Bleed
Try bleeding it in reverse by moving the slave not the pedal.
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
not to state the obvious, but you were closing the bleeder screw before he let the pedal back up right?....also check the resivour...it empties out real quick
