91 700r4 Speedo gear
Old Jul 29, 2017 | 06:25 PM
Faolan's Avatar
What gear would I need for this 700r4 with 3.42 diff and 215/65/R15 tires?
Old Jul 29, 2017 | 07:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 700r4 Speedo gear
Depend on the drive gear color, you would need a new vss too.
https://www.thirdgen.org/forums/engi...3-42-90-a.html
http://www.tciauto.com/tc/speedometer-gear-calculator
Old Aug 1, 2017 | 07:51 PM
Faolan's Avatar
Thanks!
Old Oct 21, 2017 | 05:31 PM
Faolan's Avatar
So I've finally decided it's time to change the gears however there's a problem. I've got 3.42 and 26" tires. A combo I've found is 15t and 40tooth. But the vss won't hold a 40tooth gear. How far off would the speedo be with a 39 tooth gear? Is there an adapter somewhere for a 40-45 tooth to be able to fit in the vss?
Old Oct 21, 2017 | 05:53 PM
Engine: Lb9
Transmission: M20
Standard motor products sc13
Old Oct 21, 2017 | 06:19 PM
Faolan's Avatar
Thanks again! my bad on not paying attention that you posted that before sorry!
1 last question. Is this a 2 pulse vss?
Old Oct 21, 2017 | 06:54 PM
Engine: Lb9
Transmission: M20
I think all 90-92 are 4k ppm
