DO A 9 BOLT AND 10 BOLT USE THE SAME YOKE?
Old Sep 26, 2017 | 08:12 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Found an aluminum 4th gen driveshaft with 1350 u joints for sale. Are they the same yoke, or would i have to find something custom for a 9 bolt to run a 1350?
Old Sep 26, 2017 | 10:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: DO A 9 BOLT AND 10 BOLT USE THE SAME YOKE?
9-bolt has 3R or 1310 joints. You would be running a conversion u-joint.
Old Sep 27, 2017 | 06:52 AM
big gear head's Avatar
All of the 3rd gen Camaros and Firebirds had the 3R U joint. If you found one with 1350 U joints then you will have to get a 1350 yoke for your rear end.
Old Sep 27, 2017 | 09:39 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Right, but would my nine bolt rear use the same as a ten bolt? I can find a ten bolt yoke for the 1350, but haven't yet found a nine bolt specific one.
Old Sep 28, 2017 | 06:43 AM
No, different splines on the pinion shaft.
Old Sep 29, 2017 | 02:34 PM
Abubaca's Avatar
Not an answer to your question, but I have an aluminum DS for sale if you're interested. Not sure if you WANTED the 1350 or not. Mine is bone stock, so it'll fit your 9 bolt. Needed a custom shaft for my TKO, so this one is just sitting.
PM if you're interested.
