speedo with th400
Old Jan 3, 2002 | 11:11 AM
BlownBird's Avatar
speedo with th400
I have an 88 Firebird with a newly installed th400. Is there any way to retain my factory speedo operation? Any companies out there making an adaptor that will convert the mechanical output to a useable signal? Is there a tailshaft out that will bolt up to the th400 and give the appropriate signal? I have not had a driveshaft made yet, so switching the tailshaft won't hurt a bit. Thanks in advance, Don Barnett
Old Jan 3, 2002 | 07:57 PM
buickman's Avatar
well, know that TCI makes an adapter for converting an electrical signal to a cable drive, you might check thier site or contact them. www.tciauto.com might also check www.hughesperformance.com
Old Jan 3, 2002 | 08:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TH400 uses the same speedometer gears as the TH700R4, so you should be able to take the VSS from a car with an electronic speedo and just stick it in.
No wait. Sorry, I lied.. the housings are different depths.
Old Jan 4, 2002 | 05:49 PM
Jay 727's Avatar
The diameter of the speedo housing is different also. I tried that before. 700R4 is 2" 400 is 1 7/8".
darwinprice
17
Oct 11, 2015 11:51 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
TrevinE
Sep 14, 2015 03:20 PM
WickedBowtie
Sep 11, 2015 11:24 PM
