Torque arm Bushing
Old Feb 18, 2018 | 12:01 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Torque arm Bushing
How important is the torque arm bushing? I'm trying to fit a TR-6060 trans and there is clearance issues with the Holley crossmber torque arm bracket and the trans output flange. Can I trim it down or bolt the arm right to the crossmember?
Old Feb 22, 2018 | 09:54 AM
Re: Torque arm Bushing
It's important. I wouldn't want to do without one.
You can't really bolt the TA to the XM since it has to articulate as the rear suspension moves up and down going over bumps and accelerating and whatnot. Gotta have some freedom of motion in certain directions.
Trimming might be an option. I'd have to see a photo of it however, to even guess whether it would be OK to do.
Old Feb 23, 2018 | 10:28 AM
TJQIROC's Avatar
Engine: 6.2 Gen V
Yea, I am thinking that trimming would help. The bushing and bracket extend about 2" or so. If I bend a smaller bracket and cut the bushing down, that would work. Eventually, someone will come up with something. That big flange on the transmission. It is just like the yoke on the rear. All that would be needed is some company to just make a bolt on yoke with a u joint.
Old Feb 23, 2018 | 10:40 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You could always do a tq arm tunnel mount system
Old Feb 23, 2018 | 01:00 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
I didn't know that was possible. I'll do a search to see if that will help. I don't need much, maybe another inch or so.
Here's what I am dealing with
Old Feb 23, 2018 | 01:11 PM
midias's Avatar
Jegster made kits for a while not sure if they still do.
https://ls1tech.com/forums/attachmen...d-dsc00418.jpg
You could also do this
http://www.jegs.com/i/UMI-Performanc...791+4294829509
or
http://www.umiperformance.com/catalo...roducts_id=133
Old Feb 23, 2018 | 01:13 PM
midias's Avatar
Alston makes one too
https://www.thirdgen.org/forums/susp...ed-torque.html
Old Feb 23, 2018 | 02:09 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
I think the Jegster is not available and I cannot find the Alston. The other ones either go off the cross member or hang too low. There doesn't seem to be much info available for the Jegster or Alston, as in long term use.
Old Feb 23, 2018 | 02:14 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
I found this but nothing on Youtube or this site. Anybody hear of it?
https://www.lmperformance.com/660193...nt-f-body.html
Old Mar 13, 2018 | 01:04 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
I think I will be ok with the torque arm. I cut down the bushing and made up a new bracket, about 1/2" thinner. I now have about 1/2" clearance from the flange. Bracket was a little tough to make without any metal working tools.
1/2" clearance
ls1>*
Feb 1, 2010 11:51 PM
dave mc
Sep 5, 2009 04:28 PM
Pablo
Jun 1, 2004 11:08 PM
vegaken
Dec 4, 2003 08:45 PM
