rearend gears
Old Jan 6, 2002 | 05:37 PM
19WS6T/A91's Avatar
rearend gears
I was considering swapping my 3:23's for some 3:73's. is this worth the money and the trouble? i know that generally speaking on mustangs you will see close to a second 1/4 gain. i was just wondering if its the same with our cars.
Old Jan 6, 2002 | 06:19 PM
ede's Avatar
ede
it was worth it to me when i swaped gears. only you can really answer the question, but you will feel the differance.
Old Jan 6, 2002 | 08:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
With a TPI motor, probably not, because the engine doesn't make any power at the higher RPM that it would be forced to run at; or more accurately, it makes less at the higher RPM than it does at the RPM it runs at now. That's especially true with an essentially bone-stock one like your sig makes it appear. You have done nothing to move the engine's power band upwards, so a gear change might even slow your car down.
Old Jan 7, 2002 | 05:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I agree, 3:73s aren't the best idea for a stock TPI intake. I went from 2:73s to a posi 3:73, after the cost of parts and labor, it was such a waste of money, especially since I was heading off to college in a month.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
