1-2 Accumulator piston Stuck
Old Sep 8, 2018 | 04:43 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
So I'm tearing this 700r4 down for a rebuild and found the 1-2 Accumulator piston stuck in the bore. It's stuck in there pretty good. Anybody ever encounter this? Maybe this is why they junked the poor firebird I got it off of. If this is the case you have no second gear right?
Old Sep 8, 2018 | 05:56 PM
Re: 1-2 Accumulator piston Stuck
No. If the accumulator is stuck, then it doesn't accumulate.
Its job is to absorb the first incremental bit of fluid being sent toward the band servo for the 1-2 shift, to cushion the shock. If it's stuck, i.e. not accumulating, 2nd gear probably slammed pretty hard.
Old Sep 8, 2018 | 06:47 PM
Incidentally, you can eliminate the pin that it rides on, by getting "pinless" ones from Sonnax https://www.sonnax.com/parts/2520-pi...tor-piston-kit and maybe others. The same part fits both 1-2 & 3-4. Drill acoupla holes in the factory one(s) if you want, yank out with a dent puller or something, clean up the bore(s) if necessary (probably not but heh...), and put the better one(s) in instead.
The more usual way they fail is by wearing the pin bore to the point that the fluid all leaks out and no pressure every builds up. Hence the point of the "pinless" design.
Old Sep 14, 2018 | 01:09 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Cool. Thanks for the info. Much appreciated. I'm gonna try swapping housings. Piston looks good, just gets stuck in the housing.
Old Sep 14, 2018 | 10:55 AM
Pro Built Automatics's Avatar
The pin must be in there straight and tight. The piston must not wobble on the pin or replace it. Most of the time the pin is worn and the pin hole in the piston is worn out. Bore must mot have any scratches. If there is any scratches and they cannot easily be smoothed out, you will need another housing. If you are using a TransGo Shift kit, you will not be able to use the Sonnax pinless setup.
327_TPI_77_Maro
Feb 13, 2008 12:14 PM
91NiteRida'
Feb 6, 2004 05:35 PM
FJK
Mar 16, 2002 05:22 PM
GreenProStreet
Mar 1, 2002 06:21 AM
91banditt2
Aug 20, 2001 04:23 AM
