T5 Swap Wiring Questions
Old Sep 23, 2018 | 11:51 AM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I'm nearly finished with my 700R4 to T5 swap but I have a couple of wiring questions.
I used two wires off of the automatic shifter harness for the clutch safety switch and two of them for the backup light switch. No problems there. I terminated the two remaining wires individually, insulated them and bundled them up under the dash. Is this correct (safe). I don't want any shorts and I don't want an electrical fire.
Also, I'm not sure what to do with the two wires that came from the light bulb socket that lit the auto shifter. I cut the socket off. Should I terminate / insulate those two wire separately or should those two wire be terminated together to complete the circuit? Again I don't want any electrical gremlins with the interior lighting, etc.
Any help will be much appreciated.
Old Sep 23, 2018 | 12:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T5 Swap Wiring Questions
If you tie them together, it will be a short.
Terminate/Insulate them separately.
Old Sep 23, 2018 | 12:59 PM
You could have just left the socket in there, with no bulb in it. Since you already used your dykes, as should not have been done, just tape them off. Don't short them together; your instr lp fuse will blow.
Pretty sure the wires for the clutch safety switch and the T-5 backup light switch are already in the car from the factory; but it shouldn't bother anything to extend the corresponding ones from the auto shifter.
Old Sep 23, 2018 | 01:42 PM
Max's Avatar
Max
Thanks.
shrop
Apr 11, 2005 08:59 PM
