Why no endplay after rebuild?
Old Oct 10, 2018 | 12:56 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
So I'm almost finished with my v6 700r4 rebuild .
Just waiting on a shift kit. But when I install the pump, I have no end play. I can still turn the input shaft easily both ways. The ONLY major part I replaced was the sunshell with the upgraded hardened one from gm. Before I disassembled I had good amount of end play.
Stock washer is # 69 that sits on the input drum. When I installed the input drum into the case I made sure the reverse drum was sitting on the sunshell.
Then I pulled the input shaft up and down to check for the play it's supposed to have. But when I install pump I have no end play? Is this expected?
I replaced every seal, bushing, clutches and steeles. I ordered some of these "700R4 4L60E Pump stator to input drum shim .015".
Sonnax 77409-15" just incase.
I was thinking maybe I didn't install the input drum all the way down past the last clutch?
I'm gonna check evrything again.
Old Oct 10, 2018 | 01:32 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Re: Why no endplay after rebuild?
Spoke to soon. I was checking endplay with the trans horizontally. I checked it vetical and it has some endplay but seems like very little. Hmm.
Old Oct 10, 2018 | 04:12 PM
morgsie's Avatar
Same thing happened to me when i built my first 700r4 years ago. need to check end play with input shaft pointed to the sky. get a dial indicator to get an accurate measurement. I think .015" to .036" is "spec". IIRC, you can run the 4L60Es to a tighter .005" i've been told it's ok to run the 700s that tight but don't quote me on that.
Old Oct 12, 2018 | 02:17 AM
Pro Built Automatics's Avatar
.005" to .025' is fine.
Artem
May 8, 2004 03:56 AM
hpjspdr4l
Dec 11, 2003 12:32 AM
LT1guy
Mar 26, 2003 09:37 AM
urbman
Oct 14, 2002 08:45 AM
88TAJeff
Sep 25, 2001 11:59 PM
