.005 pinion shims available?
Old May 27, 2019 | 03:12 PM
rottweiler68's Avatar
Car: '89 Iroc
Engine: 383 TPI
Transmission: Built 700R4
Axle/Gears: 9 Bolt - 3.45
Are there any .005 pinion shims that for the BG 9 Bolt? The smallest I’ve seen and that came in my kit are .010
Old May 28, 2019 | 10:25 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: .005 pinion shims available?
I think my kit came with .007 at least, I think they were Yukon or Ratech. I got them off Rock Auto
Old May 28, 2019 | 10:33 AM
Car: '89 Iroc
Engine: 383 TPI
Cool good to know, thank you! It would make it much easier if they would list the sizes that come in the kits.
Old May 28, 2019 | 11:00 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Yeah, it does suck but...
Here is the list on Yukon. I think I got both pinion shim sets and only used one though... not sure which one I used. If you PM me after 5pm EST I can take a look at what I have left and measure some of them for you
https://www.yukongear.com/partslist....+%26+Shim+Kits
Old May 28, 2019 | 11:05 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
At least the shims are cheap
see if this works...
https://www.rockauto.com/en/catalog/...ion+shim,15152
The Yukon part numbers equate to the USA STANDARD GEAR part numbers. only about $14 for the two sets
Old May 28, 2019 | 11:07 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I also used the solid pinion spacer here
7.75 9 Bolt Part No. 4114
http://ratechmfg.com/gmsolidspacers.htm
IROCZ1989
May 13, 2019 08:56 PM
Keoman
Aftermarket Product Review
Apr 14, 2013 09:39 AM
JPhillis
May 11, 2009 09:31 PM
DTL504
May 23, 2004 06:13 PM
TomP
Aug 14, 2002 07:01 PM
