3.73 or 4.10 Rear gear with 18x10.5 rear tires
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
Good day,
Looking for some thoughts.
I am wanting to change the rear gear ratio on my IROC. Currently have a fourth gen rear installed.
Rear tires are 18x10.5 (285/35/18) and the wheel/tire is a little over 26 inches tall.
What would be an appropriate rear gear to use with this wheel/tire combo. Been debating on either 3.73 or a 4.10.
Car is NOT daily driven, I do care a bit about gas mileage as I do a lot of back road driving with the car but I also want to launch hard from a stop and be able to break the tires loose if I want to.
Engine is not stock and has a Mini-Ram installed.
Thoughts?
Thoughts?
Re: 3.73 or 4.10 Rear gear with 18x10.5 rear tires
I'm running 275/40/18 in the rear of mine with a t5, 4th gen rear and 3.90 gears. Seems to be a happy medium. It launches very well and pulls like a freight train, but at cruising speed it doesn't rev to the moon.
The transmission that's in your car will make a difference in your choice as well...
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Car: '89 Firebird
Engine: 7.0L
3.42 axle ratio gives more than enough final drive ratio for a typical street performance engine with 700R4 trans. Think in terms of final drive ratio, not the axle ratio.
dust3r
Exterior Parts for Sale
May 31, 2010 08:27 PM
dust3r
Apr 29, 2010 07:10 PM
rce2win
Wheels and Tires
Nov 17, 2009 09:57 AM
Gen X Mar0
Wheels and Tires
Oct 24, 2009 08:11 PM
