Is this flywheel to far gone?
Old Jul 15, 2019 | 04:17 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Is this flywheel to far gone? This came out of a 97 LT1 Camaro. I am in the process of swapping a T56 in my 91 Camaro. If this one is to far gone what do you recommend for a replacement?
Old Jul 15, 2019 | 04:41 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Is this flywheel to far gone?
You have to measure the thickness to know whether it can be resurfaced. Looks like it hasn't been ground though, I would say it is probably usable. If it's a stock-ish rebuild I have gotten away with just using the DA sander on the surface to knock the glaze off and give the new disc something to grab, no ideal, but it works.
Old Jul 15, 2019 | 06:51 PM
GeneralDisorder's Avatar
Resurface it. Should be just fine. And lighter. Don't be the guy that doesn't resurface his flywheel. That looks pretty burnt and will probably have hot spots. Needs surfacing for sure.
GD
Old Jul 15, 2019 | 07:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, have it surfaced and thickness checked
Old Jul 15, 2019 | 11:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you're installing a new disc with a freshly machined (or new) pressure plate, you need to resurface it.
If it is from a donor car that was known to run and drive, and you're reusing the clutch, don't resurface it.
SageMoonblade
Jul 27, 2014 12:08 AM
devestator_x
Car Audio
May 13, 2013 04:35 PM
Carlos773
Dec 27, 2010 05:11 PM
Tony89GTA
Jun 23, 2010 12:44 AM
HCR13
Oct 15, 2007 04:01 PM
