Replacing 10 bolt, 28 spline clutch plates?
Car: 90 Formula / T-tops
Transmission: MD8
Couple of questions? Is this an easy job, is it recommended if diff is already apart? I see lots of reference to Yukon Dura-Grip differential on these rebuild kits, not sure what that is. Don't seem to be finding anything for stock GM?
Is it better to just buy a new, "loaded" carrier with clutches installed?
Re: Replacing 10 bolt, 28 spline clutch plates?
Stock GM = Auburn
Trash
Not rebuildable, no replacement parts available
Replace it
Trash
Replace it
Transmission: MD8
Is it factory? it's an Auburn, isn't "good", never was "good" in the first place.
You can tell if it's worn out by locking one axle and trying to turn the other. Should take around 60 ft-lbs give or take. Can't recall the exact "spec" but it's not one of those things where it has to be THAT EXACT NUMBER, like if it's 61 it's great but if it's 59 the matter will collide with the anti-matter and annihilate the entire known universe into a black hole centered on your driveway. Rather, you'll likely find that it's something somewhere in the ballpark, in which case it's still more or less working, or it's ZERO... not hard to figure it out from there.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
IrocZ'85
Feb 4, 2013 06:36 PM
