Stock Engine Angle on 82 Camaro
Old Nov 22, 2019 | 10:29 AM
Noone's Avatar
Hi!
Please can anyone tell me the stock angle meassure on the balancer from an 82 Camaro or Firebird with a stock 305 SBC in It?
The engine pointed down but i must know how much.
Thanks for your help!!!!!
Martin
Old Nov 22, 2019 | 09:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Stock Engine Angle on 82 Camaro
Engine should not point down in front. You sure your springs are okay? Motor mounts?
Old Nov 23, 2019 | 02:22 AM
Noone's Avatar
Hi!
I mean the engine pointed down to the rear.
I installed a th200r4 and wanna know the factory angle of the engine mounted in the car.
thanks
Martin
Old Nov 23, 2019 | 03:40 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I assume you're doing this to set the mount correctly for the 2004R?
Then I'd look at the angle of the output shaft and match it to the angle the pinion is at. i/e if pinion is 2degrees up, set shaft 2 degrees down. This would be for just street/normal driving.
If you plan on racing/etc, then adjust accordingly.
But, that said, factory carb'ed vehicles usually had a 3 degree tilt in them.
PS Remember that the angle you are seeing if laying on the balancer pulley is only relative to the pinion angle. i/e if your parking spot slopes 3 degrees down and your pulley is 3 degrees opposite, you'll read Zero on your gauge...keep that in mind.
Old Nov 23, 2019 | 09:52 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
In the end, it should be your pinion angle that makes the determination of that 'engine angle'. If you have an undamaged car, undamaged mounts throughout the drivetrain, that means trans and r e too, any angle adjustment necessary will be to optimize the pinion angle.
Old Nov 23, 2019 | 11:05 AM
skinny z's Avatar
Originally Posted by Noone
Hi!
Please can anyone tell me the stock angle measure on the balancer from an 82 Camaro or Firebird with a stock 305 SBC in It?
FWIW the stock factory engine angle is 4 degrees. That is, 4 degrees up at the front. On a carbed application, the carb pad on the intake is cut at this angle so as to ensure the carb sits level. Once you've achieved that, the pinion angle will be set next and that is equal angles front and rear. By default then the pinion would be up by that amount. In unusual situations, (such as what we discovered with the LS swapped Chevelle), the pinion nose was down but it matched the inclination of the downward crank centreline.
Old Nov 24, 2019 | 08:37 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Hi!
Martin
Get an angle finder (Home Depot sells one for $10.00) and measure your car's pinion angle. Then set the tailshaft angle the same amount by either changing the trans mount or shimming it.
heavy_chevy29
May 30, 2013 10:17 AM
Trevor86TA
Jul 17, 2011 08:43 AM
gmanuel
Dec 9, 2002 06:45 PM
pitpens
Oct 25, 2002 01:08 PM
Ozzy88GTA
Dec 2, 2000 05:57 PM
