Opinions needed
Old Feb 17, 2021 | 12:54 PM
91rs406's Avatar
Car: 91 camaro
Engine: 406
Transmission: 4l70e
Axle/Gears: Ford 8.8 4.10
Opinions needed
I’m new to this forum and new to forums in general as this is the first time I’ve ever signed up for one.
I finally finished the car I’ve always wanted. I started with a very clean 91 rs 305 tbi from California. I built a 509 block 406 with a balanced eagle rotating assembly w/ h-beam rods and flat top pistons, 11:1 cr, hydraulic roller cam 242/248 duration at .50 .584/.579 lift on a 113 lsa, AFR 195cc eliminator L98 heads, comp ultra gold 1.6 roller rockers, Vic jr intake #2975, ez efi fuel injection, msd ignition, 1 3/4 hooker super comp long tube ceramic coated headers and a 4 inch single exhaust. 4l70e transmission with manual valve body and a vacuum modulator to control line pressure using a 4000 rpm 9 inch torque converter. A Ford 8.8 with disc brakes and 4.10 gears I built myself. All tubular and adjustable suspension components front and rear. Full interior car with ac. I installed a very good cooling system for both the engine and transmission. Weights 3250 with me in the car. Engine should make 550 hp. My question is, will this car hook and if so what 1/4 et and mph would you estimate it’ll run? And any suggestions to add or change on my build would be greatly appreciated as this is my first all out build.
BloodBassist
Mar 26, 2013 11:52 PM
zacharyhorn
Oct 24, 2007 01:21 PM
invaderzim1915
Jul 24, 2006 05:55 PM
Apok
Jan 21, 2005 09:32 AM
