Advise for rear end gear ratio
Old Jun 23, 2021 | 07:25 AM
ahowardv's Avatar
Hoping someone can help! I have a 92 Camaro I am changing the rear end. Currently car has a drum brake rear end. I have a disk brake rear end from an 85 trans am I’m wanting to put in it. Had a company go through the rear end to make sure it looks ok first. He is saying it’s a 3.27 ratio borg Warner from Australia. Should I keep that ratio in the rear end or is there another gear set I should be looking for while he has it there? I’m going to keep the car mostly stock just upgrade brakes and suspension. Thanks.
Old Jun 23, 2021 | 07:54 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: Advise for rear end gear ratio
3.27 is a good gear for these lower rpm cars.
Old Jun 23, 2021 | 08:41 PM
vorteciroc's Avatar
Top Answer: 1
The only regularly available new Gear-Set for the Third-Gen Borg-Warner Differential is a 3.70:1 ratio Set.
Old Jun 24, 2021 | 01:41 AM
NoEmissions84TA's Avatar
Not knowing what a previous owner might have done, you need to measure the length of both of those rears - axle to axle.
The 92 rear should be shorter and require wheel spacers to keep the tires in the same location.
Old Jun 24, 2021 | 09:38 AM
As said, 3.27 is an all-around "decent" ratio; not exactly "performance" oriented, but much more nearly so than some other options. Most likely it'll be fine for you, as far as just that one detail goes.
The one thing you're going to HAVE TO deal with though, is the brakes. That 85 rear will have the crappy Delco-Moraine system with cast-iron calipers, that are notoriously ... BAD in every way. Their hydraulic requirements are CONSIDERABLY different from drum brakes, meaning, your existing master cylinder and proportioning valve are not a good match for them. And then of course there's the matter of getting them to work at all, and then keeping them working long-term.
IMO there's more to be considered here than just the gear ratio. Personally, I wouldn't make that swap, but that's just me.
Overall length should be the same as what you have. 82-92 were all the same length, about 61½" between the wheel surfaces of the axle flanges. 93-up are longer, at about 64". The rotors or drums add another 3/8" or so overall to that.
Old Jun 24, 2021 | 10:08 AM
ahowardv's Avatar
Thank you, that’s good to know. I figured on changing the master cylinder and valve. Is there a replacement option for the brakes? I would like to get away from the drum brakes and 2.73 gears currently on the car. Thanks again.
Gallileo60
Mar 9, 2007 04:19 AM
kileschilke4
Oct 13, 2005 05:13 AM
VERTIGO Z28
Mid-West Region
Apr 19, 2004 01:54 AM
676983camaro
Feb 4, 2003 06:04 PM
