torque converter
Car: FIREBIRD TRANS AM GTA 1987
Engine: 5.7
Transmission: th700
torque converter
Hello,
what are the symptoms of a torque converter? And what can cause it to fail?
Thank for your feedback
Re: torque converter
But I'm guessing you're REALLY asking, what are the symptoms of a torque converter FAILURE. In which case, usually it's strange noises, or metal in the fluid. Or in the case of a lockup one, failure to lock up.
Engine: 5.7
Transmission: th700
ok, then I am not on this problem, in fact, I have a problem on downshifting on 2-1, with a little clunking or bump or litle jump(sorry for the term I am french), only in D, in OD no problem !
For example when I arrive at a stop, when I brake gently => problem detected and if I brake hard, it is not detected....
I have changed the mount trans, yokes are good...check the tv cable, flush fluid trans........ where could this come from? Gouvernor ?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
when in D the over run clutch is engaged and a little clunking or bump when downshifting is normal
Engine: 5.7
Transmission: th700
Perhaps a problem resolved after 1987 on the TH700R4 ? I don't know the evolution of TH700R4 ...
Ah ok "the over run clutch" is engaged only on D and not in OD ?
Yes newer transmissions had more refined valve and fluid passage control of things, improving all of that. The 4L60E and 4L65E use the same clutch arrangement, and similar refinements continued during its production run as well.
Engine: 5.7
Transmission: th700
ok thank for your detailed feedback ! .. and a new adjustment of the cable TV will not correct this sensation ?
I have already done but that never change anything ... with minimal adjustment only because I know, it can be dangerous... for transmission
Engine: 5.7
Transmission: th700
This one for example.
There is this kit also, perhaps it can be benefit ? => https://transgo.com/product-details/700-jr-shift-kit/
Engine: 5.7
Transmission: th700
Hello, in fact, little rectification of my problem, it is in décélération on the dowshifting in 3-2 not 2-1 only in D. Perhaps it is the same explication, and that mean be as a a feeling of disengagement of the transmission, disengagement of the clutch, like a jolt and which goes up to the transmission shaft behind.
As described above, the shifts between 2nd & 3rd is the one where the band must let go and a clutch operate, or vice-versa, therefore is the one most likely to be affected by the servo in your situation. Not the 1-2 or 2-1 shifts. And yes, as also previously detailed, it's more likely to happen in D than in OD, because the "overrun clutch" is engaged in D only, not OD, which prevents the "low roller clutch" (a sprag) from decoupling a portion of the behavior when in D.
1st gear: forward clutch only is operating
2nd gear: forward clutch stays operated and band applies
3rd gear: band releases and 3-4 clutch applies: note that one clutch (the band) must release and the other (the 3-4) apply simultaneously
4th gear: forward & 3-4 clutches remain applied and band operates
As the car coasts top a stop and the transmission downshifts, the inverse of each upshift event occurs. Specifically, as it shifts down from 3rd to 2nd, the 3-4 clutch lets go and the band applies. In OD the low roller clutch (sprag) almost eliminates engine braking during that downshift, but in D the overrun clutch is applied and thus maintains the hard coupling through the transmission including engine braking. That's why you feel the imperfection in the 3rd-2nd downshift more in D than in OD. Since UPshifting in either D or OD is far more important to transmission operation than DOWNshifting, the timing of all the valves and orifices and accumulators and whatnot that control the clutches and band, is optimized for UPshifts; and DOWNshifts end up being just whatever they are. Furthermore, since the car is supposed to be driven in OD all the time except in a few particular circumstances, what the transmission does in D (rarely used) is somewhat sacrificed in favor of behavior in OD (almost always used). In other words, you're largely wasting your time worrying about it.
Engine: 5.7
Transmission: th700
