Pro 5.0 shifter
Old Sep 20, 2024 | 10:38 PM
Turchman's Avatar
Pro 5.0 shifter
Really happy, easy install and made a big difference.
Old Sep 20, 2024 | 11:07 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: Pro 5.0 shifter
Did you reinstall the rubber boot that covers the hole in the sheet metal hump? There's a template included with the shifter that shows where to cut into the rubber boot so it fits tightly around the base of the shifter. Without that boot sealing the floor, you'll feel a lot a heat coming up through there.
Old Sep 21, 2024 | 03:16 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Pro 5.0 shifter
Pro 5.0 is a favorite of mine for the T-5.
Old Sep 21, 2024 | 07:53 PM
Turchman's Avatar
Re: Pro 5.0 shifter
Yes I did, I didn't have to cut it at all. It fit fine
Old Sep 23, 2024 | 10:01 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Pro 5.0 shifter
How did you stretch the boot over the base of the shifter?
Old Sep 23, 2024 | 10:27 AM
Turchman's Avatar
Re: Pro 5.0 shifter
You bring up a good point; I only fit it over the shaft and not down to the base. I need to pull the console off and do that. It has been bugging me that the shift mechanism is exposed to the elements as the old shifter had a rubber boot and the new one doesn't. I was only thinking about keeping dust and water out of the interior. Thank you!
Old Sep 23, 2024 | 04:25 PM
LAFireboyd's Avatar
Re: Pro 5.0 shifter
I searched the net for pictures of installed shifters w/boots. There are many variations of incorrectly installed boots. And while some look like they'll seal better than others, none completely protect the shifter from the weather below because the shifter is below the rubber boot, and it's not supposed to be.
Here's a photo of the directions, describing how the boot should be cut, and showing it being stretched over the shifter. Cut the hole in the rubber boot smaller than the gold stop ring, then carefully stretch it over the ring and bolts, and it will close tightly beneath the ring and seal out the weather. The other photo is of mine showing the boot installed correctly.
Old Sep 23, 2024 | 05:52 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Pro 5.0 shifter
Love the Pro 5.0
Old Sep 23, 2024 | 08:20 PM
Turchman's Avatar
Re: Pro 5.0 shifter
Got it done, thanks for the tip!
Old Sep 23, 2024 | 09:32 PM
midias's Avatar
Re: Pro 5.0 shifter
Looks great and now you won't get road dust in your shifter
t/aws61985
Jan 21, 2024 03:23 PM
NUNZI 534
Sep 25, 2023 10:18 AM
banksGTA
Jun 2, 2022 07:19 AM
gt4373
Nov 11, 2020 05:39 PM
Daytona_83
Aftermarket Product Review
Jun 28, 2010 07:51 PM
