10 Bolt rear Differential?
Old Dec 30, 2024 | 02:23 PM
marauder101's Avatar
Old Dec 30, 2024 | 02:41 PM
Re: 10 Bolt rear Differential?
Could be. That POS Gov-Bomb, Grenade-Lok, whatever you want to call it, has been blowing up in a number of models of differentials over the years, including several models of GM 10-bolt. Can't see enough of the rear to know how many bolts hold the cover on, let alone, in case there are 10, which 10-bolt it is.
Old Dec 30, 2024 | 03:09 PM
Thanks, do you know anything about how to get it out of there?
Old Dec 30, 2024 | 04:32 PM
Same as any other carrier in a C-clip rear.
Remove the axles. Unbolt the 2 caps and pull it out.
Old Dec 30, 2024 | 05:25 PM
Copy that, thanks.
Old Jan 1, 2025 | 03:47 AM
IslaCook's Avatar
I had the same issue, my problem is solved, Thank you so much.
Spoiler
go_topless
Sep 3, 2022 03:12 PM
I rock 88
Dec 14, 2016 03:05 PM
kitt23
Dec 26, 2014 07:50 AM
GOY
Brakes
Jun 7, 2005 05:36 AM
Jester
Jan 14, 2003 03:02 PM
