Question about speedo drive and driven gear
Old Feb 10, 2002 | 10:29 AM
idrag2's Avatar
Ok so I finally deside that I am going with 3.42's in my bird, my buddy GAVE me a good rear end....so I gotta use it.......ain't no gears like free gears....but anyway, Can anyone help me out with the tooth count that I will need to make my speedo right? Any help at all would help me out........BTW I have a 700R4 tranny, Thanks guys:hail:
Old Feb 10, 2002 | 10:40 AM
Jay 727's Avatar
http://www.tciauto.com/tech_info/speedo_gears.htm
You'll need your tire diameter and drive gear tooth count in order to use the link above. It's the most accurate way I have found to get the right gears.
Old Feb 10, 2002 | 01:44 PM
idrag2's Avatar
Ok I have no clue how many teeth are on the drive gear now.......but my tire dia...is 25.5
Old Feb 10, 2002 | 01:50 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
15 and 41. A quick search of this board found me that. You should have a 17 now...
Old Feb 10, 2002 | 05:42 PM
idrag2's Avatar
so right now I have 17 and 41..............but with 3.42 I will just have to change the drive gear.....15... BTW right now I have 2.73's does this change anything?
Old Feb 10, 2002 | 06:05 PM
Jza's Avatar
Jza
It's much easier to change a driven gear (one bolt), than a drive gear (have to remove tailshaft housing). Just a thought when picking out your gears.
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
