replacement limitd slip unit
Old Feb 19, 2002 | 07:07 PM
jamesbern's Avatar
I don't recall exactly what the name was, but I have seen a few posts about an S.L.P unit for about $100, is this right? If not what is it called and where do I get one. The original limited slip is not servicable and will give up very soon. Thanks!
Old Feb 19, 2002 | 08:20 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Do a search for info. keyword: SLP posi
SLP's web site is:
http://www.slponline.com
Old Feb 20, 2002 | 07:46 PM
jamesbern's Avatar
Thank you
Old Feb 21, 2002 | 09:21 AM
mhaskell's Avatar
i checked slp and the unit is now on sale however i also need the four spider gears in the read end. Does this slp kit come with them? if not where can i get them?
Old Feb 21, 2002 | 10:11 AM
u r sofa king we tah did's Avatar
that posi is for a 10 bolt, and 10 bolts only have 2 spyder gears.
Old Feb 21, 2002 | 11:44 AM
mhaskell's Avatar
ok i'm a little confused now. I have a 1992 trans am 350, it has a 10 bolt read end and when i had the diff. cover off last night it had 4 gears in a square to the right of the ring gear. I am assuming it is a posi given the type of car and the fact that it had four springs in between the spider gears? ANy help on where i can get a posi unit and the spider gears?
thanks in advance -mike
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
