700R4 Govenor mods.
Old Feb 26, 2002 | 06:06 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
700R4 Govenor mods.
Can you Custom Tailor the shift points, by grinding of slight amounts of matereial from the wieghts..
And. do they sell Govenor kits, with a few spring/ wieght choices?
Anyone know?
Old Feb 26, 2002 | 06:13 PM
Jay 727's Avatar
Yes to all three questions. Lighter weights make wot shift points higher and has a little effect on part throttle shifts too.
Springs effect part throttle shifts, stronger = earlier part throttle shifts; lighter = later part throttle shifts.
Old Feb 27, 2002 | 08:56 PM
Car: 1986 Z28
Engine: 355
Transmission: th400
Thanks.
Reason Being. My Trans in the Z, still has the STock govenor from the 86 LG4, yielding 4500rpm shifts, a far cry from what i need, shifts around 5800-6000.. my next question is... Can i lighten the wieghts sufficiently to give me that shiftpoint, or not.
the question folliwing that how much are the govenor kits, and are they readily available if I screw up
Old Feb 27, 2002 | 11:23 PM
drive it's Avatar
Originally posted by Pony Killer
Thanks.
The kits are available from most catalogs-PAW, Summit etc. for about $25.00
You'll need the kit! There are 6 diff. wgts and 6 diff. springs in the kit from B&M. The combo's are endless..... I just spent three days+ getting mine pretty much dialed where I want it! So allow some time..... You'll find with some combo's it'll shift 1/2 lower than 2/3 and then others will give you higher rpm 1/2 shifts, and the "right " combo will put them real close.
If anyone is really going to do this feel free to e-mail me for the gory details-after the first day when I realized it wasn't going to be that easy I started taking notes.....
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
