Camaro RS 10-bolt rear
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
I just got a 91 RS, and I am planning on swapping the motor out. I have the stock 10-bolt GM rear end, and I was wondering how much HP they can really handle. It doesn't have posi, so I was thinking of putting in an Auburn posi unit. Is it worth the money? Would it be strong enough to handle 350-400 HP?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Your best bet is the SLP take-off torsen posi unit for $99 (http://www.slponline.com/) and a set of used gears from a 4th gen car (3.23 or 3.42). Dont forget to change the speedo gears in the trans, too. People have run 12's in the stock 10-bolt so you should be ok. Other people have stock engines that have broken 10-bolts. Its all a toss-up.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Camaro RS 10-bolt rear
hectre13
Dec 11, 2023 08:14 AM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
