whiney rear
Old Mar 4, 2002 | 09:18 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
whiney rear
i've noticed when im driving especially on the parkway and i let my foot off the gas i hear a whining sound coming from the rear end. when i hit the gas it goes away.
i changed the rear end fluid yesterday and did not notice any metal in the fluid or visible damage (didn't really know what to look for anyway lol) im preparing to hear my rear end is toast is it affirmative??
Old Mar 4, 2002 | 09:58 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
It depends.
Some types of ring and pinion gears (Richmond) are known to whine exactly the way you are describing.
Your gears may not be aligned properly, but if that was the case you would probably have more serious problems depending on how long its been driven since any work was done.
I think GM sells an additive that is supposed to help prevent this, but I don't know the name or how well it works.
Old Mar 5, 2002 | 11:30 AM
Bobbyz's Avatar
Engine: 350 "ZZ4"
i brought the car to a shop yesterday to have it check out.
the mechanic didn't see any damage to the gears he said it can possibly be some seal in the axle or something like that cause when it was on the lift he took the driver back tire and was able to wiggle it up and down just a bit and the passenger side was tight does this make sense before i pay him to do it.
Also when i brought the car in it was only making noise when i took my foot off the gas and now it's making noise all the time.
thanks
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
