NOn third gen...but need advice
Old Mar 6, 2002 | 08:59 PM
Joshua Leslie's Avatar
ok, I think I can pick up my brothers 94 grand am for about 500 bucks,.
the problem is, the car is a 5 speed manual, however, the car has lost 1st and 2nd gear, and reverse grinds,the car is driveable, but its just nofun when u start out in 3rd gear.
the engine is the quad 4 if it helps
what is the problem here? is it an easy fix?
Old Mar 7, 2002 | 07:24 AM
82camaro's Avatar
Car: 82 camaro SC
Reverse grind could be the clutch is toast and not disenguaging. If the syncro's are worn for 1st and 2nd(partially from the clutch problem) it won't go into those gears. Just a possibility. Start with the clutch first. If you stil have tranny problems, I would just get a used junk-yard tranny for cheap.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
