Flywheel weight
Old Mar 10, 2002 | 09:23 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Flywheel weight
ok I have a choice between a 15 lb vette flywheel or a aftermarket billet 30 lb flywheel. Running a 305 with a super t-10 with 3:50 gears. I know the 15 lb will rev quicker do to less rotational weight but will it have enuf inertia? thanks, Bob
Old Mar 10, 2002 | 12:12 PM
Ghour_Demon's Avatar
The lighter flywheel will of course rev quicker, but it will also cause the rpm's to drop quicker as well when you lay off the accelerator. If you have to drive in hilly or mountainous roads, the engine will constantly have to be highly revved just to keep the same speed as the heavier flywheel.
I imagine there should be a large difference since the lighter one weighs half as much as the other.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
