ZF6 clutch kit on T56?
Car: '87 Camaro LT
Engine: 355 L98
I've got a centerforce dual mass flywheel/clutch/pressure plate for a ZF6 sitting around. When I go to put a T56 in, can I use these?
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ummmm i dont think so
not unless you buy the adapter plate for the t5 bellhousing and get your driveshaft shortened
so its what is the lesser of two evils
No, I don't believe that you can use a ZF clutch for the T-56. The T-56 uses a different style than any other GM trans that I know of and I'm pretty sure that the ZF uses a standart type of push diaphram. Although I could be wrong.
ummmmm someone makes an adapter plate to bolt a T5 bellhousing to a T56.........i believe you would be able to use a conventional clutch but you would need your driveshaft shortened
so i think the real question is: what the hell are you talking about?
j/k
j/k
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: ZF6 clutch kit on T56?
j/k"............................. so wheres the T5 come in at?
sofaking, both the zf6 and the t56 use a pull style clutch, so the question is still up. The t-5 uses the conventional pull style clutch.
UT, when i get my t56 clutch parts in come over to my house and compare it to your zf6 clutch and see if they are similar or not.
Car: `86 SS / `87 SS
Night rider327
Sep 2, 2015 04:17 AM
