rear end gear help someone!!
Old Mar 12, 2002 | 02:13 AM
Harley83's Avatar
i have an 88 26 spline 2.73 (junk) posi rear end gear. i was wondering if there is gonna be any problems switchin to a 3 series gear and if the 2 series 3.73 richmond gears will go in fine without hassels... sad enough right now im on a half way tight budget so im gonna keep the 26 spline and trash the posi idea cuz i really dont benefit greatly from it anyways. im keepin the 700-R4 tranny and was also wonderin what gears should be used the 3.42's or the 3.73's for the two carrier... i know im gonna probaly start an argument over 3.42 or 3.73 but just anyones honest opinion would be greatly appreciated.
Old Mar 12, 2002 | 04:47 AM
ede's Avatar
ede
you can't put 3 series gears on a 2 series carrier, or vice versa. not really clear on what you're doing or asking, but i hope it clears it up for you.
harley why the skull and cross bones, you a traveling man?
Old Mar 12, 2002 | 08:52 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: rear end gear help someone!!
It realy depends on what you have done to the engine, on what gears you need. I just removed my 373 rearend and installed a 342[ temporily] while I'm rebuilding. Quite a bit of differance in the two. I'm running a comp cams xe268 cam in a tpi engine. It likes the 373s much better, over all. Running 30 mph in town with the 373s is much smoother. From a roll I can't tell much differance. I had richmonds, and they do WINE. I never realized how much untill I put the 342s in. I believe there's more companys than richmond, that make the gear you're after.
Old Mar 13, 2002 | 08:20 AM
82camaro's Avatar
Car: 82 camaro SC
If the posi is OK, just install some 2 series 3.73's. Install won't be too bad, you may not need to change any shims since you will still be running the same carrier and housing. I'm running 2 series 3.73's.
Old Mar 14, 2002 | 01:01 AM
Harley83's Avatar
thank yall for helping me man i really appreciate it.. moderator what i was talkin about was the richmond 3.73 2 carrier series.. i dont travel much just a big heavy metal fan lol. i know them 3.73's make quite a bit of noise but i can deal with it i guess. but thank yall for the help i really appreciate it..
Old Mar 14, 2002 | 01:09 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
im in IL, im megadeth freak, and AZ(Mustaine)
gear and carrier swaps arent one of the easier things to do to an axle of GM's design, IE unremoveavle center section like on ford 9" axles
have fun....!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
