what model is the 5 speed in 84 or 85 ?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what kind is it and what model is it and howw good is it ? will it take a 350 engine in front of it without dying ? can i find a stock bellhousing to put a V8 in front of it when it had a 2.8L before ?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its the non world class version. I've got a world class version and its handling my 350 so far. No a V6 T5 isnt recommended for a V8. It's not worth it. It wont bolt up without modifications either.
Engine: 4.3L Z TBI
unless i swapped bellhousing, yeah, who makes T5 anyways? richmond ?
any other info on them ?
thanks!
thanks!
Borg-Warner makes the t5. The V6 version has different ratios and some say that it is a weaker trans as well. You can make the trans work with a V8 but as Kevin91Z said, it's not really worth it because in addition to the bellhousing, a custom clutch needs to be made because of the different spline count on the input shaft.
Engine: 4.3L Z TBI
ewwwwww thats crappy lol. hmm well if i was to get the car thne i would want ot put a v8 in it and if I had to go to the trouble to swap the 5 speed out for a stronger tranny, then i would just go for an auto trans , but hmm thats alot of work also.... hmmm
pass... poor car though... its nice, but,,
thanks guys!
thanks guys!
[Sold] T5 electric speed sensor
Eric-86sc
Sep 7, 2015 02:10 PM
